Not able to change to $25 plan.
So today I was trying to downgrade my Koodo plan from the $60 2GB plan to the $25 talk and text only plan but when I went through the self serve it was missing. I was wondering if anyone else was having this problem because I don't want to have to pay Koodo $10 just to downgrade my plan.
Thanks,
Ryan
If you cant do it yourself on self serve, there is no $10 fee.
Just let them know you dont see it on self serve
Just let them know you dont see i...
I will give it a try. Thanks for the reply.
They changed my plan and they did confirm that I would not be changed for the change. Thank you for the help.
Just a note. This $25 plan is NOT Canada wide. Your 100 minutes are local calls only. If you make long distance calls, then there will be long distance charges.( $0.5/min)
