New self serve - How to turn on international roaming
In the new self serve, I can't figure out how to get to the add-ons. We are travelling this week, and I need to turn on international roaming. I am only seeing options to change my plan. Down at the bottom of the page it says: What’s new with Self Serve? Now you can turn on/off data usage alerts to your phone Soon, you will be able to buy a roaming add-on Does this mean I can't currently turn on roaming?
If you're not given the option of add roaming add ons via self serve then you'll need to call Koodo and ask them to add the options for you. . Since you can't add it yourself they shouldn't charge you to do it.
Hello LM
Actually it is possible to add those add ons via self serve. Just log in to your account and click on the account details. After, click on the 3 stripes and then phone sevices. Here's a picture to help
Then you will have these options
Ok, mine looked a little bit different than yours, but I found it. After clicking on Phone services, I had to select one of the two phones on the account, and it brought up a screen with "your current plan" and "change my plan" below that. But then at the bottom on that screen, it had a section that said "can't find what you're looking for? try one of these links". From there I could select "Add-ons" and it took me to the options you showed above. Thanks for your help!!
No problem. Have a nice day
