If I get a newer unlocked Iphone can I just insert the sim card from my old Iphone and I’m ready to go?
All the data is backed up from my old Iphone.
Is there anything else that I need to do?
Best answer by MilkyWay
Yes, you can use your existing SIM card. You can also swap your old SIM card. If you want to do that, you can follow the instructions here. https://www.koodomobile.com/en/help/koodo-sim-support
