More flexible data usage alerts
With the recent change to the data usage alerts, sending us a notification by text when you reach 50% of your data allowance as well as 90% I feel like we should be able to choose when we receive the first notification.
Honestly, 50% is really quick for a notification and I wish we would have the option to receive the notification at 75% or 50% and keep the 90% notification. Especially when there are plans with 2 to 3gb of data, using half of it really doesn't mean you used that much considered your allowance.
Better yet give us the option to deactivate data at exactly 100%
You are able to set that manually on your phone (if you have an android phone)
Yes as he said up there if your using an android device you have a data usage tab in your settings you can see lot's of details in there!
That would be a great idea! I absolutely agree!
Is there a way to shut it off at 100% on an Iphone 5 or is there an account setting in Koodo that can be used for that purpose?
Kim Dyment wrote:
Is there a way to shut it off at 100% on an Iphone 5 or is there an account setting in Koodo that...
There is not. You need to monitor it yourself.
