Monthly Plan, data rate
Hi, my monthly plan includes "Per per use data". Does it mean I can use the data service anytime without having to call in advance to activate the service? And, what's the rate if I'm here in Montreal or travel to elsewhere in Canada? Thanks.
Yes, it does. The rates are listed here: https://shop.koodomobile.com/plans/plans/index.html At the bottom of the talk and text plans.
Hi the Lin, to add something to Timo's answer... As long as you have a Canada Wide plan, you can use your data anywhere in Canada, there are no different rates for the pay per use when using in different areas...
