LTE not working after changing my deal
  • 9 January 2019
  • 3 replies
  • 73 views
I didnt have any lte on my phone because I had the smalest balance (i didnt have data). But I changed my balance january 3rd and when i activate my lte, I have no internet. What do i have To do, I Guess with my SIM card...? No instructions when changing my service 🙄. Thanks!
Best answer by Paul Deschamps 9 January 2019, 16:05
Make sure you are using Koodo’s APN peripherals in your settings menu.
APN: sp.koodo.com
Proxy: 74.49.0.18
Port: 80
Username: leave blank
Password: leave blank
Server: leave blank
MMSC: http ://aliasredirect.net/proxy/koodo/mmsc
MMS Proxy server: 74.49.0.18
MMS Port: 80
MCC: 302
MNC: 220
Authentication type: No set
APN type: No set
hi,
Which plan did you change to? and are you a prepaid or postpaid customer?
Can you make call and text? if you don't have data in your plan, do you need LTE?
APN: sp.koodo.com
Proxy: 74.49.0.18
Port: 80
Server: leave blank
MMS Port: 80
MCC: 302
MNC: 220
APN type: No set
Unless you have VoLTE, calls and texts are only available in 3G and data is only on LTE
