Link Accounts Broken
  • 20 July 2019
  • 9 replies
  • 284 views
Best answer by Allan M 21 July 2019, 09:39
I know you'll probably mention that koodo is a self serve brand and should fix it but you and I both know the answer is, that's the old self serve that is mostly now not supported, the feature is not currently available in the "new" self serve, and you'll have to contact customer service to do this if you wish.I wasted ~20 minutes on the phone just to add the Pay-Per-Use Intl Long Distance add-on when it should take seconds. Not wasting more time on this.
Facebook messages? They take little to no time at all to type and send at all and someone can help you that way?
Just the once or is it consistent?
Still broken.
Still broken.
You're a community veteran by now... so... I feel almost embarrassed to ask, heh. Did you try Ctrl-F5?
I can't check if ours works, because I don't think the WHP has that menu (or I just haven't searched hard enough, which is not at all unlikely either)
😤 I get the error after entering the information and clicking Continue.
Gotcha, you werent very descriptive and I didnt have a second account to test it out with. I'll take your word for it.
Good flag though regardless. They should (and I know are almost done/working on) completely getting rid of access to the old SS.
Did it ever work?
https://community.koodomobile.com/self-serve-66723/linking-your-self-serve-account-to-another-account-is-unavalible-at-this-time-3499295
https://community.koodomobile.com/billing-66726/linking-accounts-4888206
and 8 months ago https://community.koodomobile.com/self-serve-66723/combining-accounts-7791232
