LG G6 question
  • 22 January 2019
  • 7 replies
  • 142 views
I was finally able to go get an upgrade on my phone. I decided to go with the LG G6, So far its a pretty nice phone. My question is how do I get the Caller ID to work? I pay for caller ID and it did work on my LG G4, not sure why the caller id, doesn't come on with the LG G6?
Best answer by Mats 22 January 2019, 01:05
Incoming caller ID should work on your G6 unless a person who is calling you blocks it. It could have to do with how the contacts were transferred to your G6. Try removing a contact who shows as Unknown when they contact you. Then add that contact manually and have them call to see if their number shows up.
https://www.koodomobile.com/help/call-display
See if these instructions are what you're looking for
https://videotron.tmtx.ca/en/topic/lg_g6/hiding_your_phone_number.html#step=1
I should have added, I meant for Incoming calls. No numbers show up and all say Unknown
In the phone app, go to settings and make. Sure caller ID is enabled.
Also try taking out the sim and putting it back on again and restarting the phone
I tried all that, and still the Caller ID doesn't work. Makes no sense, put sim back into my G4 and it works.
If you tried all that, I would suggest you reset the phone to its default factory settings and see if it can help. You might need to backup all of the data before doing so.
Userlevel 4
Did you get your problem solved with your lgg6 ?? And how does the battery life last on the Lgg6 thanks
