I noticed that Koodo has the shock data information letting you know the percentage of data you reached however I’m not getting a single notification. I’m also going to try to buy some extra data as I need it URGENTLY but it won’t send me any options to buy some extra data which I really need.
I assumed you are a postpaid customer?
Normally, the data notification should be on automatically. Can you follow the instruction to check if the notification was on https://www.koodomobile.com/en/help/data-usage-alerts
As well, how much data have you used this billing cycle already? have you reached 50% yet?
Not sure what type of phone you’re using, but maybe this will help:
on an iPhone: https://helpcenter.trendmicro.com/en-us/article/tmka-19068
or on an Android phone: https://support.google.com/fi/answer/9458407?hl=en#zippy=%2Cset-limit-automatically-turn-off-mobile-data
Login to the community
