I want to "add on" to my daughters phone. Can I use self serve?
Only if your daughter's phone is under your account
Userlevel 2
I don't see any reason why not.
Userlevel 3
Hey Michael! if you're referring to adding/removing a feature, then this is possible via Self Serve. If you're referring to adding another phone (person), this can only be done at a Koodo Store with the account holder. To find the nearest point of purchase: http://koo.do/locator123. Hope this helped! ________________________ If you see a good answer, give it a star.
