I have used my 100 MB bundled data. Do they still charge $10 if i will not use any additional data. PS- I am on $30 monthly plan.
I have used my bundled data(100 MB) and now it is showing $10 additional data charges on self serve, but I have not used any additional data. Do they still charge $10 if i will not use any additional data. PS- I am on $30 monthly plan.
so as long as your device does not access any additional data, then you wont be charged. i recommend turning your data off to avoid additional charges.
 the koodo data counter is considered correct. your device may differ because koodo rounds your data up.
100MB is also a very very small amount. I use that up in one 20 minute ride to work sometimes. If your usage indicates you are exceeding your plan's allotment, then you should look into changing plans to something with more data. This is 2016, not 2010. Phones eat up more data than ever.
Did you get the notification when you reached 100% of your data bucket Loveneet?
how much extra data do we get for $10?
Hey Don, The answer to that question varies from one customer to another. Check your plan details in self serve for the correct information.
