how to access my message using another phone?
i will travel abroad and I want to check my messages. I know there is a way to listen your messages using another phone, but I don't know how
Userlevel 4
From the other phone, call you cell phone umber. When you hear your greeting, press * then it will ask you to enter your password. This will NOT cost you anything on your Koodo bill as you will not using any airtime to do that
Remember though, dialing your number abroad will result in long distance charges for the person who's phone you will be using to check your messages.
Userlevel 4
Ahmad wrote:
Remember though, dialing your number abroad will result in long distance charges for the person w...
Monkeyfeathers! I knew I forgot something. Thanks, Ahmad 🙂
