How do i get a new SIM card?
  • 15 July 2019
  • 3 replies
  • 89 views
I have lost my SIM card. How do I get a new one with the same number? The self serve requires to call me but since my line isn't working, I don't know what to do. Thanks!
If you need a new sim card then you will have to visit a store.
The sim card is $15 and they can activate it with your number and plan there in store.
Great! Thanks, Allan. Much appreciated.
For future reference, here are the instructions if you do not have the old sim available
https://www.koodomobile.com/help/koodo-sim-support
