how do i add us talking and texting add ons with self serve
You want to add US roaming...once you've determined which roaming package you want, click on the tab 'Plans and Add-ons' and select from there.
yes but they are not there , the 3 day bundles
You meant you see the 10 day add-on but not the 3 day ones? I can see them all.
@ Paul - does your account have a spending limit?
got it thanks for the help
Did you just scroll down the list? 🙂 I see the add-ons are not in order.
got er done thanks for the help
yes i found them thanks chris
