how can i see my calls made
Best answer by Jorden 15 April 2013, 04:27
Before your bill is posted you'll need to check the call history on your phone. This can be different depending on the model so what phone do you have? If you're trying to see ones from previous billing periods, you need to go to billing, e-bill and then pick one of the bills. Your call history will be visible there.
1 reply
