Forcing me to change rate plan to upgrade phone
  • 25 August 2020
  • 89 views
Hi,
I’m in the process of  trying to upgrading my phone to an Iphone 7 and I’m currently on a a $35 a month rate plan but when I select tab small which requires a $35 rate plan it is forcing me to change my rate plan? Why is this?
Thanks
Best answer by Dinh 25 August 2020, 18:44
If you were on a grandfathered plan, you might not be able to upgrade it in self-serve. If that was the case, you might want to contact Koodo directly and ask a rep to check.
Which plan is it (in terms of texts, minutes, data). Is it $35 before taxes and what not?
Any addons you may have do not count toward the plan price. Plan has to be $35 before addons, tab fees, and taxes.
My plan is currently $35 dollars before any addons, taxes, or fees. So that should not be the issue.
$35 per month for 2GB of data, unlimited texts and unlimited Canada Wide Calling.
It should work unless it is a BYOD plan.  You will need to contact koodo to look into what is going on with your account.  Send them a private message via facebook or twitter
