Find MEID/ESN for Samsung C414M
Hi there, I am transfering from one phone to another and the Koodomobile interface asks me to enter the ESN/MEID for this phone. However, I can only find it's IMEI (it's a Samsung C414-M) under the battery. Can anyone help with this one ? Cheers,
You just need to enter the sim card number you are inserting into the phone. If you are using an existing active sim card then you just insert the sim and no changes are required on SelfServe
Thanks Dennis!
Vincent Langin wrote:
Thanks Dennis!
No problem. Glad I could help!
