OK..I’ve tried….various codes on my phone.
called your numbers
Used your website and links
Nothing works to end seasonal hold on my phone. I’m in a two week isolation and need this done !
called your numbers
You can send a private message to Koodo via Facebook messenger or dm via Twitter to get it sorted out by a Rep. If you cannot wait until its done and must be reached via phone you can use a free VoIP service such as Fongo or Textnow(which is currently making all calls and texts free…) and get a Canadian number to use
Have you logged into your self serve and changed your plan to a current in-market plan?
If so, what error are you seeing?
I click on change plan and it says “something went wrong.try again later”…….this is as far as I can go
I’m having the exact same issue. I’m in quarantine and have no phone
I also tried to get a rep with no luck
Also is your email for the community the same as your self serve login email?
Yes to both questions. For now I’m using fongo so that helps.
thanks
Hi Johanne...the $50.00 plan
Thanks, I was trying for the $50 unlimited calls and txt with 5 gb data plan
Hey Johanne...great job..now 250 300 1625 is my wife….can you do the same for her….same plan
oops...wrong info of course...My wife would like a cheaper plan pllease
Here is a screen shot of what the website says above
OK. put her on the 50.00 plan
Actually i would like just the $35 one with unlimited calls and text instead. Don’t really need data right now. Thanks so much for your help . Sarah
go for it
June would like the same plan (35.00 ) if available
Ok sounds good thanks
sarah
