email
i cant find my account info?? my email is not working
Did you set up and register for self serve? You have to register for it first before you can use it. Did you forget your password? There is a link called forgot password on the login screen. If it just plain ole buggered up then you need to call Koodo (*611 on a koodo cell) and they can reset your self serve account for you
Did you already sign up for self-serve and now you can't log in? If so, I'd recommend either the "forgot password" or "forgot username" option on the side of this page: https://secure.koodomobile.com/account. If that doesn't work, you need to call *611 and they can assist you from this point If you haven't signed up for self-serve, you need to do that first here: https://secure.koodomobile.com/account/Registration.portal
