Double Canada wide plans issue
Userlevel 3
So I signed up for the 45$ canada wide data plan last month, this billing cycle is only for this plan. I've had some confusing events which I'm not sure what to make of. 2 days ago I got a notification stating I had use 75% of my data. Think this was odd since I know I hadn't used 750mb so far this cycle, I check self serve which shows I've only used 400MB of 1524MB. Ok so the notification was wrong, likely sent out from the previous limit of 500MB. but how did I get the extra 500MB(1524MB instead of the 1GB)? I'm not complaining if Koodo wants to give me a extra 500MB a month, but I don't need to get charged for it. Which I'm not sure if this will happen yet as billing cycle still has a few day left. Anyone else have this oddity of a possible explanation ? Oh and I have 2 lines on the same plan and both are showing the 1.5GB, not sure if the 2nd line got a notification for getting close to the limit though.
Best answer by Timo Tuokkola 1 April 2013, 18:49
sounds like the plan was switched mid billing cycle. Data doesn't get prorated so you would have 500 MB under the old plan and 1 GB (1024 MB) under the doubled version for a total of 1524 MB.
1 reply
