Data usage text alert problem
why I've get a txt message that my data usage is 92% my plan is 5 GB and I've only use 2.2
Where do you see the 2.2? If it's on your phone's data counter, it may not be accurate. The most accurate way to check your data usage is via Self-Serve (website or app). Now, your data usage doesn't update in real time in Self Serve, so there may be a delay in case you recently used a lot of data. But seeing as you posted this 2 hours ago, it should be reflected in your Self Serve. If your usage there is still nowhere near >90%, you may wish to call customer service to inquire. 611 from your cell, or:
Yes, there is currently a delay on usage updates for Koodo...so it is not in real time. you likely hit it hours ago...
