Connection problem's
I can not receive text, updates, and messages without wifi connection. Why is it only working with wifi?
Hi Brianna, There could be many, many possible causes for that, but we can get to the bottom of your issue 😃 What phone do you have? Do you have call access? Do you have data set up on your phone?
What kind of phone do you have?
I have a Samgung galaxy ace With the plan of just the unlimited texting
Userlevel 2
Does this ever worked? Or worked with other phone?
When you say "Just unlimited texting", do you mean the $15 prepaid plan or the $20 "regular" plan?
15
15
Without a data booster this plan is unable to access the Internet without wifi. Also the phone has a known issue that it can not send text if wifi / data is enabled. You need to turn wifi / data off to text. It might be data to turn off. I can never remember. If you want updates and Internet you need a data booster otherwise all you get is text
