Canada Wide 50 special offer - for new or ALL customers?
Is the Canada Wide Data Double 50 only for new customers? I am trying to switch over and take advantage of the special offer on until July 2. Under 'Plans', Canada Wide 50 gets me 1GB data and 600 minutes.....but when I look at the same plan under self serve (using the little pop up window you see when you hover over the plan name), it only shows 500 MB and 300 minutes. Which is correct?
Best answer by Timo Tuokkola 22 June 2013, 19:56
The plan is for everyone. Odds are the web team forgot to edit the popup text. On the confirmation page when you go to change the plan you should see the doubled minutes and data.
1 reply
