Can't login: "Your login failed. Please try again".
  • 27 July 2020
  • 8 replies
  • 312 views
I can’t log in to my Koodo Prepaid account, and I am positive my login information is correct. Even when I try to reset my passowrd, I get the error message “ForgotPassword/LoginUnsuccessfulUser_LoginDisabled”.
I'd suggest then sending a private message to Koodo via Facebook messenger or dm via Twitter to get it sorted out.
Can you make sure you are logging into the prepaid self serve and not the monthly self serve
Thanks for the response. I am sure that I am logging into Prepaid Customer. I will try contacting them through Facebook messenger thanks!
Does it still happen? I couldn't login either because of maintenance but all is well now.
Unfortunately yes, still.
Aww well I'm sure Koodo will be able to help you out 😊
Hi, I am getting the same issue, has this been fixed? I need to login and get reset my password, getting the same error message. I cannot contact the support as I need to login to add credits to my phone.
This is 2 month old post and I believe OP got helped already.
You have your own post now. Let's stay in it.
