can't access prepaid self serve
I can't access prepaid self serve. Any ideas? Receving the error message below; "Dashboard/MessageNotaccessibleForCurrentAccount"
Try clearing cache and cookies then login again. Also maybe try a different browser.
Userlevel 3
Daniel I also can't to go into koodo prepaid service. Tried your method
Hi there, Self Serve was under maintenance this weekend so you might indeed have had some issues accessing your accounts. It should be working fine now 🙂 Can you try again? Thank you! ________________________ If you see a good answer, give it a star.
