Can not activate my Nexus 4 on Self Serve....HELP please
I have a blackberry curve, a while ago i bought a nexus 4 and activated it...recently i had to go back to the blackberry, my question is how do i activate my nexus again on the self serve.
Userlevel 2
If you're using the same sim card, then you just put the sim card into the phone that you want to use. If you have a different sim card, then you would do a sim card swap on your Self Serve account.
its the 8530 curve,,, has no sim card
Userlevel 2
You still need to add your sim card to your account, which can be done through Self Serve.
