can i use my other lines upgrade
  • 12 June 2019
  • 2 replies
  • 77 views
Is it fine if I upgrade my other lines phone to get a new one but just use it for myself, as the other tab is cheaper to pay then mine
Eh, you meant you had another line and wanted to get a phone with it? If so, Yes.
You could get a phone with another line and take the phone to use somewhere else.
You can actually use the phone anywhere else. All you need is a sim. You can use the phone, or you can have a friend use the phone or even sell the phone if you wanted to.
