Can I change my SIM card?
  • 10 January 2021
  • 2 replies
  • 44 views
I have successfully transferred my number from Telus to Koodo according to my Koodo self service account. What do I do next? Change my SIM card?
Best answer by MilkyWay 10 January 2021, 21:09
Did you receive a new SIM card from Koodo? If so, you should remove the Telus SIM card and start using the Koodo SIM card.
Yes, thank you so much, it worked! Thanks for the help.
