Buying new phone from koodo, phones vs prepaid phones
I am a current koodo customer with an android smartphone. I am considering purchasing a nexus 4 16gb from koodo. It is available in the prepaid phones section and the phones section. I currently have a monthly plan (not prepaid), but if I attempt to buy it from the phones section it requires me to select a plan. I was trying to just buy the phone and put my sim card into it. Do I need to select it from the prepaid phones section? It costs $50 more there.
First, you login to your Postpaid Self Serve, you click on Phones (Postpaid), then click on add to cart/Checkout, Skip change plan, you cannot use this method to click on Prepaid phones using your Postpaid Selfserve, Prepaid phones do not use Tab like Postpaid,
After you select your phone, you can just click on your shopping cart and check out. You do not need to select a plan nor buy a prepaid specific phone
