Being charged data add on we never signed up for and foes not appear under manage add ons
  • 12 August 2019
  • 8 replies
  • 346 views
I got a notice that we added 2gb of data to our plan last month but we did not do this. Now we're being charged $20/month but this add on does not appear under manage add ons so I don't know how to remove it. It's also not under manage data. We do not use over our alloted amount of data ever. So I have no idea how this extra data was added. How do I remove it if it's not under add ons?
What plan do you have?
Is the charge for data top up? Do you have more than 2lines under your account and your subscriber bought a top up?
We have 2 lines but when I look at the other line they used less than 1gb of data. I cannot access data usage for last month. We each have a 2gb plan.
“I got a notice that we added 2gb of data to our plan last month but we did not do this. “
I’m a little confused... Did you switch to a plan which includes 2GB last month?
Now they charge $20 for 2GB add-on? (It means you have 4GB total?)
Did you check your PDF Ebill? What does it say the $20 charges for?
Its not Tab charge?
No,we didn't switch plans. We've always had $45/2GB but they are billing one line for an extra 2GB. The bill says $20 2GB add on but I can't find these extra 2GB under add ons.
Ok. I’ll flag this, so rep can look into your account 🙂
Thank you! Not sure what happened but we definitely didn't sign up for this and don't need it. Thank you!
Userlevel 2
Hello @RHM ! Thank you very much for contacting us! 🙂 I have accessed your Koodo account, and I was able to see that a 2GB Data add-on had been added to one of your two phone numbers, on the 25th of June. The addition appears to have been made through the online Self-Serve portal.
Consequently, your July invoice includes a partial charge for this add-on, which corresponds to the time frame in which the add-on was active on your phone number during your previous billing cycle. The July bill also includes a full 20$ charge, which covers the add-on during the entire current billing cycle.
However, I was also able to see that, on the second day of your current billing cycle (that is, after the current invoice was issued), the add-on was removed from your phone number. As a result, your next invoice, which will be issued in August, will include a partial credit, which will compensate for the absence of this Data add-on during most of your current billing cycle, - Alex
Great. Thank you!
