Allow Data Block to be added/removed in Self Serve
  • 30 December 2013
  • 33 replies
  • 137 views
Show first post
Data is automatically ON when you fresh upgrade iOS.which is why I pay $2 for data block. so happy about that.  seriously, no sarcasm here.
Great idea for the phone you give to the kids to call you when their movie is over and they are ready to be picked up. ============== They're not intentionally trying to drive you into bankruptcy, they're just following what the culture tells them is normal.
I want Koodo to stop using data when I go over the monthly limit. Does enabling data block as an add-on accomplish this? Thanks
I want Koodo to stop using data when I go over the monthly limit. Does enabling data block as an ...An easier solution would be to monitor your data usage, turn off mobile data when not needed and use Wi-Fi, (where possible). Enabling the data block does not automatically stop your phone from using data when you reach your monthly data limit, so the answer is no.
I want Koodo to stop using data when I go over the monthly limit. Does enabling data block as an ...http://community.koodomobile.com/koodo/topics/data-and-how-to-make-the-most-of-it
I want Koodo to stop using data when I go over the monthly limit. Does enabling data block as an ...yes it does stop you from using data and i wish I new how to get rid of it! I need to download an incoming message and it wont let me cause of the stupid data blocker!
I want Koodo to stop using data when I go over the monthly limit. Does enabling data block as an ...Hi Stephanie,You can remove the data-block from your account under the add-ons section of self serve.
Idea has now been [b]implemented. (since the add-on now costs $2) :(
