account set up
  • 15 June 2021
  • 2 replies
  • 60 views
trying to set up my koodo account and it will not accept my postal code..    WHY
Best answer by Bernard Koodo 15 June 2021, 15:58
Please check and see if your postal code lines up with your address. If it does not, the system will not accept it, preventing you from setting up your Self-Serve account.
In some cases, the postal code does not work, as they pull the address from the system powered by Canada Post. This may be due to a change in the postal code, which has not been updated by the system.
In the meantime, I have flagged a rep to help you out.
@Fred Mckay Pls make sure your postal code is entered without spaces like Koodo Assists suggests.
