Will Koodo's wireless home line work with my security system
  • 14 March 2021
  • 1 reply
  • 59 views
I have an existing home security system that requires land line for monitoring. Can this wireless system be used for this purpose?
Best answer by Dinh 14 March 2021, 19:38
1 reply
Some systems require  a physical landline for it. If that is the case, you can’t use Koodo wireless homephone for it. Anyway, I would suggest you check in with the home security company for their input.
