Testing a wireless home phone
  • 22 September 2021
  • 1 reply
  • 56 views
I want to transfer my telus landlines number to koodoo but I want to test its service first, so I ordered it with a new number, will I be able to transfer my home phone to it at some point?
Best answer by BobTheElectrician 22 September 2021, 06:18
1 reply
Good move. Forward your Telus calls to your temp Koodo number for the time being.
Once you are satisfied, you can then port the Telus number to Koodo.
You may consider continuing the forwarding arrangement if you want to maintain a separate landline(internet bundling, cheaper long distance, etc.)
