will my phone with sim card works for pond inlet nunavut
would my phone work up in pond inlet nunavut?
Best answer by rikkster 24 March 2016, 06:52
Hi Bill,
Unfortunately, no. I don't see Koodo or any other carrier with coverage in the Pond Inlet, Nunavut area. You can check Koodo's coverage map below. I've provided a link to a cell site locator that shows cell towers when you enter a location.
Koodo coverage map
http://help.koodomobile.com/coverage-long-distance-and-travelling/coverage-maps
Cell tower locator (last updated, May 1st. 2015)
http://www.ertyu.org/steven_nikkel/cancellsites.html
Edit: Northwestel, (partnered with Bell Mobility), services Pond Inlet. You should be able to unlock the phone and use a Bell SIM card. Call them and see if that will work (1 888 423-2333). Bell's coverage map is not showing coverage for the area, so I'm a little skeptical.
Which phone do you have?
http://www.nwtel.ca/shop/mobility
1 reply
Hi Bill,
Koodo coverage map
