When will Koodo match Fido's 3 GB for 15$?
Fido is rating it as a tablet plan but it is 100 % usable on a cellphone.
You can port your number, you have free incoming SMS and for the rest there is 3rd party apps like Fongo, voip.ms, etc.
I give them until the end of this month to match Fido or I will have to make the switch, but I must say that it has been a fine 5 years with Koodo.
Best answer by Goran 21 September 2016, 23:27
It's still a data only plan. The sms and call rates are exorbitant because of its intention for use I tablets, even if it will work without issue. I have used it myself actually. Koodo doesn't have an equivalent plan type otherwise Koodo likely would.
1 reply
