I put in the new SIM card to activate my prepaid plan. Voicemail would not work now. I went through all the steps to record my greeting, but the incoming calls would not get the voicemail when I didn’t answer the calls. And also the selection of choosing to use the standard Koodo greeting is missing from the prompts, I had to record my own greeting.
How can I fix the problem with the voicemail?
