Sim card works but says invalid when making self serve.
  • 28 December 2016
  • 1 reply
  • 63 views
So I just bought my sim card today and everything is working, but the only problem is that I can't get it to validate when I tried setting up my self serve account.
Device: Unlocked Samsung Galaxy S7 Edge
1 reply
Hi Kevin,
The only way to get the prepaid sim to work is by setting up a self serve account. If it is activated already, you already had a self serve account. If you forgot the password for it, just click on the "Forgot Password" and you will be able to reset it.
