Prepaid. What is the charge per minute (cents) for calls in Canada
If I choose the prepaid text plan for $15 what is your per minute rate for talk (within Canada)
Hi merrill, You would need to buy an additional booster for making calls. I'd recommend buying the $25 booster, which would give you 500 Canada minutes (5 cents per minute). You can also call to the US (10 cents) or the rest of the world for 25 cents per minute 🙂
Sophia wrote:
Hi merrill, You would need to buy an additional booster for making calls. I'd recommend buying...
Oh yes your booster credit will roll over indefinitely, you don't have to use it all up in one month 😃
