Prepaid plan
  • 13 November 2018
  • 3 replies
  • 535 views
Bought a prepaid phone for my daughter , if I use my account to set it up will that stop my current plan ? Or do I need to set it up separate?
Best answer by David AKU 13 November 2018, 18:01
I suggest setting up your daughter’s prepaid phone on her own email address, or one you can eventually transfer to her. That way, when the time comes for her to manage the phone independently, she is good to go.
You'll probably have to set it up as a separate account using another email address.
You can use the same email address as your postpaid plan, but if both are prepaid, you'd have to use another email....
