Prepaid phone cards
Are you able to use a Roger's prepaid card on a koodo prepaid phone? If not can I put a Roger's prepaid sim card in the koodo prepaid phone.
Yes, as long as the phone is unlocked you can use a Rogers SIM card.
No you cannot use a rogers prepaid card on a koodo prepaid account( rogers card/koodo SIM) as they are different companies and the rogers code wouldn't work with Koodo's system.
