prepaid data outside of region
  • 19 April 2018
  • 8 replies
  • 19 views
I have a prepaid plan that allows calls and texts only within the Quebec province. This may be a silly question, but will data still work outside of Quebec and within Canada, such as in Toronto?
Yes data is Canada wide
Yes data is Canada wide Thank you so much. So a base plan doesn't change this?
Yes data is Canada wide NP... Nope data is always Canada wide nomatter what.
Icing on the cake... text and picture messaging included are world-wide, not limited to Qc or Canada.
You can look here to see where you have coverage in Canada. It'll be like 99% of population covered. http://choosehappy.koodomobile.com/network?INTCMP=KMNew_ChooseHappy_OurNetwork_CompareCoverage
Precisions:
1- your text are always Canada-Wide for receiving and Worldwide for sending.
2- your minutes are for Qc only but you can add a booster (those never expire).
Your calling will be based on what province you are in so if you are in Quebec it is all over quebec. if you go to Ontario, it will be all over Ontario. While in toronto, if you call somebody in Quebec, you need to add talk booster add-on.
Guys I think they get it no need to put the exact same thing multiple times you're just making this poor person have more and more emails sent to them about this thread without adding anything.
