Possible? Add prepaid phone to my dad's existing plan (non-prepaid plan)
I bought a prepaid phone and not activate it yet. I want to add it on my dad's existing plan (non-prepaid plan). What can I do?
Best answer by Camilo_A 11 July 2013, 00:18
Hi there Francois... Since you already have the device, you can insert a postpaid Sim Card and it will work... So it what you meant is that you will use it with your dad's line, just insert the sim card on the phone... If what you meant is that you will like to have another line under your dad's account, you and your dad will have to go to the store to get an extra line under his account...
1 reply
