Need help using my data
What can we help you with?
Do I pay for wifi
No.  If you can connect to any WIFI, it's free.
Wifi is just any internet connection that you can connect to. You don't pay any extra to use wifi on your phone. You do pay to use data on your phone (whether it's part of your plan or pay-per-use).
Change my APN From a telus
-Make sure your data is enabled on the phone in your settings menu.
-Make sure you have a valid data booster if you are on prepaid
-Make sure you do not have a data block on your account, you can check and remove it through your Koodo self serve account
-Make sure your APN settings are set to those of Koodo's (Koodo's APN settings below)
APN: sp.koodo.com
Proxy: 74.49.0.18
Port: 80
Username: leave blank
Password: leave blank
Server: leave blank
MMSC: http ://aliasredirect.net/proxy/koodo/mmsc
MMS Proxy server: 74.49.0.18
MMS Port: 80
MCC: 302
MNC: 220
Authentication type: No set
APN type: No set
Tap menu key, then tap Save. Make sure the radio button is selected to activate data.
Can u call me 780xxx-xxxx
This is a public forum and We are just customers like yourself not Koodo employees and as such we should not be privately calling other customers unfortunately. As it is a public forum you may want to delete your phone number from here as well.
It's a flip phone it's too old
Flip phones do not use data in the fashion smartphones do. There is no need to have a data package for a flip phone.
