My Prepaid Plan Is Bugged
  • 25 September 2021
  • 13 replies
  • 138 views
I tried to change my pre paid plan a couple days ago. While attempting to do so the website would load forever then eventually fail…. After i already added funds to my account to allow me to change my plan.
Now my account is stuck in some kind of limbo. It shows i am on this new plan, but my data does not work, and it shows that ill be charged in 2 days for the amount of money that my old plan used to cost.
Not only that, but my data does not work. Whenever i turn off my wifi, i get a notification to “Sign into koodo”
From your description, your texting and calling worked normally? How about your photo messaging (MMS)?
I am just wondering if you accidentally disabled cellular (mobile) data in your phone. Could you recheck it? Also I recommend you reset network settings of the phone and see if it can do anything.
Data is turned on and i can receive mms
If you can received and sent mms, the problem could be from Koodo end. I will flag a rep.
Hi @Eric Lamoureux
Were you able to use data before attempting the plan change?
Hi @Eric Lamoureux
Hi,
My old plan had 250mb of data. Up until the date i attempted to change my plan, the mobile data worked.
I think its possible that i used the 250 mb available with my old plan. That still doesnt explain why it shows i am on the new $45 a month plan, while also acting like im still on my old plan
Try re-starting the phone to refresh handset connection to the mother ship. If you ran out of data without a booster to continue, it may still think it’s in a lock-out condition.
A restart made no change. I'll update tomorrow when Koodo starts it's next cycle and hope it all corrects itself. Thanks for all the help everyone
Can you also check transaction history?
I see the balance says $45 on your screenshot.  Does the transaction is showing you how much you added and applied $45 plan, and remaining amount correctly?
So the plan renewed and deducted $25 from my balance. It still shows i am on the $45 plan, but below it shows different
It's strange that your current plan says $45..
But, on transaction history:                                    You added funds on Sep 17th. But didn't switch to $45 plan - it didn't charged $45 to switch over. Then on Sep 27th, it seems renewed on same $25 plan again. - They only deducted $25.
Transaction history and your base plan don't seem to match.
That's exactly my problem. Do you think I need to go in person to have it corrected? I have no way of correcting it online
I also have flagged this. Hopefully one of rep can take look into it 🙂
Hello! At this point, it would be best for our colleagues from the prepaid department to have a look into it. You can schedule a callback with an agent at koodomobile.com/chat. Please keep us posted if you need more help.
