Monthly to Prepaid and Keep Same Phone
I'm looking to get my first phone and wanted to get it online from koodo but for the phone I want it makes you select a monthly plan when buying online. Can I switch to prepaid after I recieve the phone I want? Also is there a certain amount of time I have to wait? I'm going to buy the phone in full and not use the tab so that won't be an issue.
Best answer by Sophia 19 July 2016, 01:35
You can switch after 90 days... So you'll have to to the math if it's worth it to you 🙂
1 reply
