is $20/month possible?
Could I get the base $15 texting plan and add on the 25 min ($5) canada wide calling. So my total would be $20
Yes, sure you can! 🙂 Though be advised that you'd effectively pay $0.25 per minute, whereas if you add the $25 booster, you get 500 minutes (= $0.05 per minute). Still, it's your choice and you can certainly do that!
Sophia wrote:
Yes, sure you can! 🙂 Though be advised that you'd effectively pay $0.25 per minute, whereas if y...
I just realized I forgot to add that the minutes you don't use roll over to the following months, you wouldn't have to pay that amount every month! The $15 would have to be paid every month. The $25 until used up - even if it takes 30 years 😃 Just to avoid all misunderstanding!
It's as easy as it looks! 🙂
I definitely recommend getting the $25 booster as it is the best value. However, if you know that you probably will never use minutes on your phone, I guess the $5 booster is fine.
