if i don't have data on my plan will my phone still go online other than wireless
Possibly.
1) You can still use pay-per-use data on a phone if you have data turned on.
2) Old plans could have a data block applied to them to prevent all data from being used by the phone.
3) Newer plans can have a data block applied at a fee of $2 / month which blocks all data EXCEPT picture messages. You could still just turn off data on the phone, but can't send picture messages.
I have mobile data turned off, should this cure the problem David ?   And thanks for the reply,  i only want to use wifi
Chris Rob wrote:
I have mobile data turned off, should this cure the problem David ?   And thanks for th...
Yes, should work just fine!
thanks again david. not new phone savy
