I want to activate my cell phone, use it when I need to, and get billed for what I use...is this a postpaid plan
  • 12 November 2014
  • 1 reply
  • 9 views
who has a service like this in Ontario Canada?..sometimes I don't use it for a month or two, but need it to work when I want to, it would be an owned, unlocked phone
Best answer by Moonmack 12 November 2014, 14:35
Well prepaid requires $15 per month (a little less with automatic payments). This gives you unlimited texting and you only pay for the minutes you use in addition to the $15 monthly. You actually buy a block of minutes, but they don't expire so long as you keep up with the monthly payment. If you have very low usage you might want to check out something like SpeakOut. They work on the Rogers network, but that may be okay for Ontario. I don't think Koodo has a suitable plan aimed at people who have very low usage.
1 reply
Userlevel 3
