I purchase a prepaid plan but sending textes messages doesnt work
Best answer by Sophia 30 August 2014, 15:30
We need more information, Roxanne... is your account active? When did you activate it? Did you port in your number (sometimes it takes a little while after porting before texting works)... If you are more comfortable writing in French, we have a French community or just reply here in French and you will be helped in that language 🙂
1 reply
